FlexGrid inconsistent behavior and row height
Posted by: guest on 14 September 2017, 11:17 am EST
    Posted 14 September 2017, 11:17 am EST
    I have two issues with the FlexGrid control.
    The first one is that FlexGrid have some inconsistent behavior when I add “wj-flex-grid-cell-template” with “wj-input-number” and “wj-auto-complete”.
    The “bug” show only the first time you click on the number or country to edit, new row adds, but the grid unexpected exits the edit of the selected row.
    The second one is when you set the “item-formatter” on the grid (you need to remove comment in js) to set the height of the row, it doesn’t size the elements inside that row (i.e. wj-input-number control, wj-auto-complete,…)
    Here is the fiddle example:
    http://jsfiddle.net/5dcsw19d/
    Kind regards
  • Posted 14 September 2017, 11:17 am EST
    I think I have a similar issue with “wj-flex-grid-cell-template” used with “wj-input-date” - only the first time I click on the date cell to edit it - the unexpected exit from the edit mode occurs. So I have to click it again.
    Thanks for reporting these issues. I have escalated them to the development team(116569) for review.
    let us know when they fix it.
    I would surely update this thread once I get any information from the development team.
    Any update on this?
    Both of these issues have been fixed and would be available in the next release. Regarding the second issue i.e. a cell editor control should occupy the whole cell space (at any row height), you can manually setting the css as a workaround. Here is the updated fiddle: http://jsfiddle.net/5dcsw19d/4/
    Note that with very small row heights like 20px our input controls will look cut off at the bottom, because of a padding used in input and button elements.
    Ok thank you for the help.
    Can you tell me when is planed to push the new release?
    The first issue is fixed in the build 50 which is available on CDN now. You can confirm the fix in the updated fiddle using latest version i,e, http://jsfiddle.net/5dcsw19d/5/
    The first issue is solved in the fiddle example, there aren’t any unexpected behaviors. I cannot find anywhere the download page, could you give me a link to download the build 50 so I can test this in my project?
    Thank you!!
    Ok thank you.
    Kind regards
  • Posted 1 March 2021, 9:43 am EST
    • "* "[i][b]```
