Flexgrid: Responsive height with CSS (Including horizontal Scrollbar)
Posted by: moritz.neugebauer on 15 May 2020, 3:18 pm EST
    Posted 15 May 2020, 3:18 pm EST
    Dear Wijmo Team,
    I’m struggeling to make the height of my flexgrid responsive to the browsers window height using CSS.
    See this simplified example:
    Title
    Description text
    of
    variable height
    .page {
    height: 100vh;
    .wj-flex-grid {
    height: 100%;
    border: 1px solid #dfdfdf;
    My constraints are:
    • Page wrapper should not be scrollable (hence the height: 100vh)
    • Height of flexgrid should only be as high as necessary (if there are only a few rows)
    • Height of flexgrid should not exceed the browsers window height
    • Horizontal scrollbars should be visible (they take up vertical height it seems)
    • Vertical scrollbars should be visible, too
    • I don’t know the height of the header-container
    To me it seems like flexgrid expects to get a fixed height but I really need to deal with responsive browsers window heights.
    I’m using Angular but I need to find a solution that works with CSS.
    Moritz
  • Posted 18 May 2020, 12:36 am EST
    Hi Moritz,
    You can use flexbox for your requirements. Just set the .page display to flex and set its height to 100vh:
    .page {
    	height: 100vh;
    	display: flex;
    	flex-direction: column;
    Refer to the sample below:
    https://stackblitz.com/edit/angular-67zcf5
  • Posted 26 May 2020, 10:29 am EST
    Dear Ashwin,
    thank you for your response. In the simplified example it works like a charme. I will try to use this solution in a more complex setting.
    Moritz
  • Posted 2 June 2020, 4:25 am EST
    Dear Ashwin,
    In a more complex setting, I’m not really able to set the height of the page container. Also there might be more containers around the page container.
    <div class="page-wrapper">
    <div class="page">
    <div class="header">
    <div class="title">Title</div>
    <div class="description">
    <p>Description text</p>
    <p>of</p>
    <p>variable height</p>
    </div>
    </div>
    <wj-flex-grid />
    </div>
    </div>
    .page {
    	height: 100%;
    	display: flex;
    .page-wrapper {
    	height: 100%;
  • Posted 3 June 2020, 2:53 am EST
    Hi Moritz,
    Flexbox does not really works with percentages. Your original requirements will be fulfilled if you will set the height of the page-wrapper or page to 100vh. As you said that you cannot set the height of the page then you may set the height of the page-wrapper class.
    https://stackblitz.com/edit/angular-cytjks
  • Posted 5 June 2020, 2:00 pm EST
    Hi Ashwin,
    thank you for your response. I see no other solution then calculating the height by using something like calc(100vh - containerOffset). Not ideal but it works.
    Moritz
