Posted 16 September 2019, 4:39 pm EST
Code example to reproduce the problem: https://stackblitz.com/edit/angularjs-a3othp?file=home%2Fhome.controller.js
Expected: column “Items” to contain only the values I explicitly set to the uniqueValues of the filter object.
Actual: the column contains all possible combinations inferred from the original collection, ignoring the fact that I set uniqueValues.
Some context:
I needed to implement a grid column with data map, capable of displaying multiple values (array), as well as filtering by distinct value. If the sought value is contained in the array, it satisfies search criteria.
I implemented it for Angular 7.x some time ago - see this original thread: https://www.grapecity.com/forums/wijmo/flexgridfilter-datamap-mul
Now I’m porting it down to a legacy AngularJS (1.x) app and faced a different kind of problem. The data is loaded asynchronously (I emulated a 100ms delay) and CollectionView object is created only after data is obtained. Looks like it resets the list of available values in the filter.
To work around it, I enclosed the entire thing into an ng-if (see template home/home.html) - uncomment the div and see how the “Items” column will have the desired options.
Is this a bug? What would you recommend?
