FlexGridFilter Various Issues or Questions
Posted by: brijeshkumar.marand on 18 February 2020, 7:14 am EST
    Posted 18 February 2020, 7:14 am EST
    We have implemented the flexGridFilter and I have some issues/questions about how the filter behaves currently.
    I have tried using the demo from the flexGrid.
    Scenario 1: Filter by value the id column by searching the id with ‘1’ and un checking the ‘1’ option. The grid now filters ‘1’ and all data that does not have the ‘1’ in the id like ‘2’, ‘3’, etc.
    Expectation: Filter just the value id ‘1’.
    Scenario 2: The filter by value does not contain all the values like ‘0’ to ‘999’ instead it shows ‘0’ to ‘249’
    Expectation: The filter value should show all the values
    Scenario 3: The filter by value, uncheck ‘Select All’ option and apply. It does not filter anything.
    Expectation: All the values should be filtered
    Please check this and suggest the right way to do this.
    Brijesh
  • Posted 19 February 2020, 3:00 am EST
    Hi Brijesh,
    Scenario 1: This behavior also exists in Excel and since FlexGrid is based on Excel, this behavior also exists in FlexGridFilter. You can disable this by setting the exclusiveValueSearch property of FlexGridFilter to false:
    var filter = new wjGridFilter.FlexGridFilter(theGrid, {
        exclusiveValueSearch: false
    https://www.grapecity.com/wijmo/api/classes/wijmo_grid_filter.flexgridfilter.html#exclusivevaluesearch
    Scenario 2: This is because the ValueFilter only shows the first 250 values by default. You can change this value by setting the maxValues property of the ValueFilter class. Refer to the documentation link below:
    https://www.grapecity.com/wijmo/api/classes/wijmo_grid_filter.valuefilter.html#maxvalues
    Scenario 3: This is also the same behavior as Excel. If we de-select all the values, there are no rows to filter out. That is why the FlexGrid shows all the rows again.
    I hope this clears your doubts. Let us know in case you have any further issues or queries.
