FlexGridPdfConverter.export does not export Footer row in ActualSize Scale Mode
Posted by: renriquez on 18 November 2025, 4:36 am EST
  • Posted 18 November 2025, 4:36 am EST
    Hello all,
    I am trying to implement exporting the currently displayed Flexgrid to a PDF document. The grid includes a footer row which details the total number of rows currently shown in the grid. It should be noted that I am also implementing exporting the Flexgrid to XLS using FlexgridXlsxConverter and the footer row is successfully exported in the XLS file. For PDF files, I have tried to export it using PageWidth and SinglePage scale modes and the footer row is present in both. Only in ActualSize Scale Mode is the footer page not exported properly, it is only present in the last page of the PDF file and not in the other pages.
  • Posted 18 November 2025, 9:00 am EST
    Hi renriquez,
    As per our understanding, your issue - After setting the scaleMode to ‘ActualSize’ while exporting the grid to PDF when the grid’s width is large enough to shift some columns to be rendered on next page in the PDF, then in this case, the Footer cells are only rendered on the last page, which should be rendered on the last 2 pages.
    It seems like an unexpected behavior, so we have forwarded this issue to the engineering team for further investigation with internal tracking ID - WJM-37230. We will update you when we have an update from the engineering team on the same.
    In case, if your issue is different from what we mentioned above, then please let us know.
