Flexsheet filter not working for merged cells
Posted by: chris.jones on 26 July 2019, 6:33 am EST
    Posted 26 July 2019, 6:33 am EST
    I have a Flexsheet filter on a column which contains merged cells. When I open up the filter some of the entries are missing. This seems to be intermittent and only seems to occur after applying a filter on a different column. It can be fairly easily reproduced using https://www.grapecity.com/wijmo/demos/Grid/FlexSheet/CellMerging/purejs
    1. In column “A”, create some merged groups
    2. In any other column, select the filter icon and filter out several rows
    3. Select the filter icon for column “A”. The filter will now often not show all of the valid entries that exist and are still visible in column “A”.
  • Posted 29 July 2019, 6:15 am EST - Updated 3 October 2022, 6:45 pm EST
    Hi Chris,
    We are sorry but we were not able to replicate the issue at our end. Please refer to the attached screenshot. Could you please tell us whether we are missing something in order to replicate the issue? You could also provide us with a sample that replicates the issue.
  • Posted 29 July 2019, 11:14 am EST
    hi Ashwin,
    Sorry that you could not repeat it. Here is a more specific example. If you still can’t repeat then I will send a recording:
    For column A select 1 to 5 - Merge
    For column A select 6 to 10 - Merge
    For column A select 11 to 15 - Merge
    For column A select 16 to 19 - Merge
    So you have 4 merged groups in column A
    Click filter for column C
    Uncheck top three 2,3,4 and apply filter. The “0” group in column A still has entries so is correctly shown in the grid
    Now press filter for column A. There is no 0 entry.
    Chris
  • Posted 29 July 2019, 11:19 am EST - Updated 3 October 2022, 6:45 pm EST
    I moved the filter to the side a bit so you can see the data underneath
  • Posted 29 July 2019, 11:27 am EST
    hi Ashwin
    Actually, having played with it a little more, I know the specific reason. When the first element of a merged group is removed via another unrelated filter then it does not show.
    Chris
  • Posted 30 July 2019, 12:45 am EST
    Hi Chris,
    We were able to replicate the issue at our end so we have forwarded a bug report to the dev team with internal tracking id 392169. We will give you an update on this as soon as we have further information.
  • Posted 30 July 2019, 9:58 am EST
    I’ve had almost the same issue a month ago.
  • Posted 31 July 2019, 12:14 am EST
    Hi James,
    We have added you as a correspondent to the case. We will give you an update as soon as the issue is fixed.
  • Posted 20 November 2019, 12:34 pm EST
    Hi
    Any news on whether this has been fixed in 2019v3?
    Chris
  • Posted 20 November 2019, 11:12 pm EST
    Hi Chris,
    The issue has been fixed in the latest 19v3 build. You may verify the same using the sample link below:
  • Posted 21 November 2019, 4:38 am EST
    Thats great. Thanks.
