FlexSheet formula parser incorrectly tests for blank string
Posted by: michael.lucks on 30 April 2019, 10:56 pm EST
    Posted 30 April 2019, 10:56 pm EST
    When a Flexsheet formula contains a condition that tests for the existence of a blank string, the test returns true when the target cell = 0. For example:
    1. A1 = 0
    2. A2 contains a formula ‘=(A1=“”)’
    In Excel, the formula correctly evaluates to FALSE – but in FlexSheet the formula incorrectly evaluates to TRUE.
    Here is a fiddle that further illustrates the behavior:
    http://jsfiddle.net/lucksm1/9f0bny2h/18/
    How can I test accurately for a blank string?
  • Posted 1 May 2019, 4:46 am EST
    We are able to replicate the issue at our end, therefore we have forwarded a bug report to the concerned team for further investigation with internal tracking id #377114. We will let you know about any updates regarding the same. Until then, you could work around the issue by creating a custom function to check if the cell is empty. Please refer to the following code snippet:
    flexSheet.addFunction('isblank', (...params) => {
        var val = params[0][0][0];
        return val == '';
    }, 'Checks if cell is empty', 1, 1);
    You may also refer to the following sample demonstrating the same:
    https://jsfiddle.net/5b1zLrcs/
  • Posted 1 May 2019, 6:27 pm EST
    Thank you for the workaround. Please notify me when the bug is repaired.
  • Posted 2 May 2019, 11:37 pm EST
    By the way, the equality test in your suggested function should be:
    val === “”
    not
    val == “”
  • Posted 8 May 2019, 3:16 am EST
    The issue with comparing empty strings with 0 returning wrong value has been fixed in the latest nightly build. You may confirm the same from the following sample which uses the nightly build:
    https://stackblitz.com/edit/js-d1roog?file=index.js
    The fix will include in the next stable release.
    Note; Nightly builds are not tested for production and should not be used in the production environment.
  • Posted 22 August 2019, 6:05 pm EST
    Thank you!
