getError not working with childItemsPath
Posted by: viethdhe130200 on 5 June 2024, 10:42 pm EST
    Posted 5 June 2024, 10:42 pm EST
    Hi Wijmo admin,
    When I updated Wijmo FlexGrid to version 5.20241.9, there is an issue with the getError function when my table has childItemsPath. This problem occurs as seen in the second table of the demo link. Therefore, I hope you can investigate why the getError function is not working for tables with childItemsPath in this version.
    Link demo : https://jscodemine.mescius.io/sample/jIKgJKnUpE6Urjy4Nl_Ldg/
    Thank you very much.
  • Posted 6 June 2024, 5:51 am EST
    This query has already been answered on our other portal, here’s a copy of the response -
    A recent update in the ‘updateCell’ (internal method) seems to be causing this issue. We have forwarded this issue to the dev team for further investigation with internal tracking ID - WJM-34036. We will update you as soon as we have an update from the dev team.
    For now, to avoid this issue you can use the following workaround -
    import * as wjGrid from '@grapecity/wijmo.grid';
    let oldFun = wjGrid.CellFactory.prototype.updateCell
    wjGrid.CellFactory.prototype.updateCell = function (e, t, i, o, n, r) {
        oldFun.call(this, e, t, i, o, n, r);
        var l = e.grid, a = e.rows, u = e.columns, c = a[t], d = u[i], v = e.cellType, E = wjGrid.CellType;
        var P = l._getBindingColumn(e, t, d), Q = (0 != r && P) ? e.getCellData(t, i, !1) : null;
        if ((v == E.Cell || v == E.RowHeader) && l._getShowErrors()) {
            var Re = "";
            !1 === r && P && (Q = e.getCellData(t, i, !1));
            var Ee = a[t].dataItem;
            Re = P.binding && Ee && P.getIsRequired(c) && (null == Q || "" === Q) ? l._edtHdl._getRequiredMsg() : l._getError(e, t, i, !1);
            l._edtHdl._setCellError(o, Re)
    Please refer to the following sample for the same - https://jscodemine.mescius.io/share/25LlchinuEmXmsvoCAnNyA/
  • Posted 14 October 2024, 2:29 am EST
    Thank you, @vivek.pannu
  • Posted 3 January 2025, 7:18 am EST
    Hi Hoang,
    This issue is now fixed. You can verify it in the following sample with the latest Wijmo version i.e. 5.20242.30 - https://jscodemine.mescius.io/share/YHYDbxhNkUybopRnM7qPDA/
