Getting error "Cannot read property 'collectionView' of undefined" while using
Posted by: nivishapanwar on 2 March 2021, 8:13 am EST
    Posted 2 March 2021, 8:13 am EST
    I am using wijmo listbox. The update and remove functionality were working fine before but now getting error “Cannot read property ‘collectionView’ of undefined”Listbox.zip
    Can I get help for this issue.
    <wj-list-box #ListData [itemsSource]=“name” (initialized)=“initListBox(ListData)”
                                (selectedIndexChanged)="displayListBoxValueInTextField(ListData)">
                                <ng-template wjItemTemplate let-item="item" let-itemIndex="itemIndex">
                                    {{item}}
                                    <div class="wj-glyph">
                                      <span class="wj-glyph-drag"></span>
                                    </div>
                                  </ng-template>
                            </wj-list-box>
    Nivisha
  • Posted 3 March 2021, 8:14 am EST
    Hi Nivisha,
    Can you let me know when exactly this error occurs? And what changes did you made before the issue occurred?
  • Posted 3 March 2021, 9:44 am EST
    Hi Ashwin,
    I have attached the code file . Whenever I try to call update or remove method, I am getting this error.I really dont have an idea why it is coming.Can you suggest me after looking into the code any other approach or idea to proceed with the update and remove .
    Nivisha
  • Posted 3 March 2021, 9:53 am EST
    @ViewChild(‘ListData’, { static: true }) ListData: wjcInput.ListBox;
    get showCheckboxes() {
    // return this._showCheckboxes;
    // set showCheckboxes(value: boolean) {
    // if (this._showCheckboxes !== value) {
    // this._showCheckboxes = value;
    // this.ListData.checkedMemberPath = value ? ‘checked’ : ‘’;
    Whenever I am using anything with ListData its giving an error.
  • Posted 4 March 2021, 11:12 am EST
    I found a temporary soln for that error.
    updateRecord(indexValue: number) {
    let textBoxValue = this.fullname || “”;
    //this.changeDetection = true;
    if (textBoxValue) {
    //let cv = this.ListData.collectionView;
    this.name.items[indexValue] = textBoxValue;
    // cv.items[this.ListData.selectedIndex] = textBoxValue;
    this.name.refresh();
    this.saveListBoxData();
    <button type=“button” class=" btn btn-primary btn_update" [disabled]=“isOkDisabled”
    (click)=“updateRecord(ListData.selectedIndex)”>Update
    Now I am able to perform update and remove. But not able to add checkboxes in the listbox. Could you please help me with that because now I am getting the same error for checkedmemberpath.
    Nivisha
  • Posted 5 March 2021, 1:03 am EST
    Hi Nivisha
    Sorry for the delayed response. I tried to replicate your issue by copying your code in a new application but was unable to replicate it.
    Please make sure that the spelling of ListData is the same in both HTML and component side.
    I am adding the sample for reference:
    https://stackblitz.com/edit/angular-9-0-0-rc-1-2ngzsw
  • Posted 5 March 2021, 2:11 am EST
    Hi Ashwin,
    The spelling is same. Even I did not understand why this issue came. Can you help me with adding checkboxes as I found a soln for update and remove but not able to add checkboxes in listbox.
    Nivisha
  • Posted 5 March 2021, 3:28 am EST
    You can try binding the checkedMemberPath directly to the showCheckboxes variable on HTML side:
    https://stackblitz.com/edit/angular-9-0-0-rc-1-v8h4ax
  • Posted 5 March 2021, 6:52 am EST
    I tried like that but it did not work. Does checkedmemberpath doesnt take collectionview variable as the variable which I am passing in item source is of type collection view.
    Nivisha
  • Posted 8 March 2021, 12:16 am EST
    Hi Nivisha,
    The checkedMemberPath property is of ListBox and not of CollectionView. Your issue may be arising because you have added the wjItemTemplate directive which does not define any checkbox to display.
    I have updated the sample to fulfill your requirements:
    https://stackblitz.com/edit/angular-9-0-0-rc-1-nfjukl
  • Posted 8 March 2021, 2:20 am EST
    Hi Ashwin,
    Thank you for the help, the soln worked for me.
    Nivisha
