Grid column filter values are not encoded in url
Posted by: bozjator on 3 December 2019, 11:07 am EST
    Posted 3 December 2019, 11:07 am EST
    I have a problem with special chars in values in column filters.
    If i want to filter column by value “word1 & word2”, the & sign is not encoded in the url and i get an error.
    Here is an example of call that a grid makes after setting a filter: domain.com/odata/table?$format=json&$count=true&$skip=0&$top=200&$filter=((ColumnName%20eq%20’word1%20&%20word2’))
    So in the url, in the part %20&%20 you can see that & sign is there in a normal “shape” and is treated the same as the & between $skip=0&$top=200 (so its treated as a part of url and not as a part of value for filtering).
    Is there a way to make filter values encoded?
  • Posted 4 December 2019, 1:55 am EST
    As per your question, you are using the OData API to show the Data in FlexGrid API. The FlexGrid provided built-in collection view for OData, named ODataCollectionView. Please refer to the following demo sample for reference:
    https://www.grapecity.com/wijmo/demos/Grid/Data-binding/ODataAPI/purejs
    In the sample, as we applied the Value Filter for Two values using the Filter Dialog, the Server call will be as follows:
    $format=json&$inlinecount=allpages&$filter=((CustomerID%20eq%20%27ALFKI%27)%20or%20(CustomerID%20eq%20%27ANTON%27))
    The above observation is with the latest build 2019v3.637. Please let us know if you have any further queries.
    Manish Gupta
  • Posted 4 December 2019, 6:17 am EST - Updated 3 October 2022, 6:11 pm EST
    I think we don’t understand each other.
    Here is an example from page for which you give link (please see the image below):
    I was filtering column Company Name by the word “word1 & word2”, and this gives an error, because this word is not properly encoded to be put into url. You can see it on the image.
  • Posted 5 December 2019, 12:35 am EST
    Hi Blaž,
    We have forwarded the issue to the dev team with internal tracking id 409351. We will update you as soon as we will hear from them.
  • Posted 23 January 2020, 5:16 am EST
    I think this was fixed in Wijmo Build 5.20193.646
    Can you please confirm this?
    Is there a list of all fixes that were made in Wijmo Build 5.20193.646 ?
  • Posted 23 January 2020, 6:02 am EST
    Yes, the issue is fixed in the latest release build.
    PFA: Fixes in the latest release.
    ChangeLog.zip
