Grid itemFormatter manual raise event
Posted by: paul.jeremiah.go on 4 October 2018, 8:25 pm EST
  • Posted 4 October 2018, 8:25 pm EST
    Would there be a ts code that can manually trigger the itemFormatter func?
    We have a requirement that after a particular action ran, we need to apply cell formatting.
    this.grid.itemFormatter = (panel, r, c, cell) => {
    if (cell && r >= 0 && panel.rows[r].dataItem) {
    	const matches = this.list.filter((x) => {
    		return panel.rows[r].dataItem[this.Key] &&
    			x.field === panel.rows[r].dataItem[this.Key];
    	if (matches.filter((w) => { return w.Code === "A" }).length > 0) {
    		cell.classList.add("a-class");
    	else if (matches.filter((w) => { return w.Code === "B" }).length > 0) {
    		cell.classList.add("b-class");
    We already applied the formatting but we would still need to move the horizontal scroll bar before itemformatter get called and the customize color bindings would apply.
    Paul
  • Posted 4 October 2018, 10:30 pm EST
  • Posted 21 June 2020, 9:13 pm EST
    is there an example on how to unit test this itemformatter with the cell.classList.add ? Thanks
  • Posted 22 June 2020, 3:35 am EST
    Hello Meera,
    In the test spec, you can find the first row that matches the this.Key condition. You can use any random data as this.Key. Once you will get the row, create a className variable and assign it according to the Code.
    After this, get the cell element and check whether the class list has the appropriate class.
    Please refer to the sample attached.
    itemformatter test.zip
  • Posted 22 June 2020, 6:06 am EST
    Thanks Ashwin.
