Gridfilter filterchanged event not firing
Posted by: sneha.nagaruru on 28 July 2021, 1:39 pm EST
  • Posted 28 July 2021, 1:39 pm EST
    Hi Team,
    I using Wijmo grid which contains wijmo filter. To save and restore filterdefinition when filter is applied / changed I’m trying to fire filterChanged event.
    Note: Grid data is loaded not on Oninit but after performing some action
    below is the code related filters
    Html
    <wj-flex-grid #flexGrid class="bento-flex-grid has-row-hover" [class.list-grid]="isListGrid"
                [itemsSource]="data" [stickyHeaders]="true" [showMarquee]="true" [showSort]="true"
                (initialized)="initGrid(flexGrid)" [headersVisibility]="'Column'" [allowSorting]="'MultiColumn'"
                (selectionChanged)="onSelectionChanged()">
                <wj-flex-grid-filter #gridFilter [showSortButtons]="false"
                    (filterChanged)="onFilterChanged(gridFilter, $event)">
                </wj-flex-grid-filter>
    .ts
    @ViewChild('gridFilter', { static: true }) gridFilter: wjcGridFilter.FlexGridFilter;
    @ViewChild('flexGrid', { static: true }) flexGrid: wjcGrid.FlexGrid;
    [b]//mostly used for clearing and refreshing filter or when grid is refreshed in my code [/b]
    this.gridFilter.clear();
    this.gridFilter.grid.refresh();
    HideActionFilter() {
        const col = this.gridFilter.grid.columns.getColumn('actions');
        const cf: any = col ? this.gridFilter.getColumnFilter(col, true) : {};
        // switch filterType to 0 if filters hidden, otherwise to filterType defined in model
        cf.filterType = 0;
    [b]//this method is called on init and to show/hide Filters[/b]
    toggleFilter() {
        this.toolbarConfig.filtersHidden = !this.toolbarConfig.filtersHidden;
        if (this.gridFilter) {
          // if filters are hidden, clear the grid filter
          if (this.toolbarConfig.filtersHidden) {
          // iterate through columns to filtered
          for (let i = 0, il = this.gridColumns.length; i < il; i++) {
            // get column and column filter
              this.gridColumns[i].binding
            cf.filterType = this.toolbarConfig.filtersHidden ? 0 : 3;
          this.HideActionFilter();
    [b]
    //recently added onfilterChanged code[/b]
      onFilterChanged(filter, args) {
        if (filter.cancel) {
          return; //filter not applied
        this.filterDefination = filter.filterDefinition;
        this.onSaveStateClick();
      onSaveStateClick() {
        var state = {
          filterDefinition: this.filterDefination
        localStorage['myworkgridState'] = JSON.stringify(state);
      onRestoreClick() {
        var json = localStorage['myworkgridState'];
        if (json) {
          var state = JSON.parse(json);
          // restore filter definitions
          this.gridFilter.filterDefinition = state.filterDefinition;
    Can you please provide a resolve.
    Sneha
  • Posted 29 July 2021, 5:12 am EST
    We have created a code sample using provided code snippet but we are unable to replicate the issue at our end. Please have a look at the sample and let us know if we are missing something to replicate the issue:
    Code sample
    https://stackblitz.com/edit/angular-qeptxl?file=src%2Fapp%2Fapp.component.ts
    Feel free to update the above code sample to reproduce the issue.
