Posted 21 December 2017, 9:23 am EST
Have this example http://jsfiddle.net/Wijmo5/9swqo8jj/ for Angular 2+? I looked but could not find it. I want to do Header Filter in Flex Grid
Posted by: namigabdukerimov on 21 December 2017, 9:23 am EST
Posted 22 December 2017, 1:53 am EST
Please go through following demo sample for the same:
http://demos.wijmo.com/5/Angular2/HeaderFilters/HeaderFilters/
~Manish
Posted 25 December 2017, 2:55 am EST
How do I get the open source code?
Posted 26 December 2017, 1:58 am EST
You may get the Source code online from the following link:
http://demos.wijmo.com/5/SampleExplorer/SampleExplorer/Sample/HeaderFilters/Angular2/Code
You may also get the source code within samples folder shipped with downloaded build at the following location:
C:\Users\Admin\Downloads\C1Wijmo-Enterprise_5.20173.380\Samples\TS\Angular2\HeaderFilters
~Manish
Posted 8 January 2020, 6:01 pm EST
Hi, I need to make header filters, just like these in the latest version of FlexGrid. Will it still work? Any chance you have a reactjs sample? Thanks!
Posted 9 January 2020, 1:14 am EST
Hi Scott,
Please refer to the link below for the sample in reactjs:
https://stackblitz.com/edit/react-q1fygd
Posted 10 January 2020, 10:12 am EST
Thanks! This is quite a bit of coding required for this feature. Is there any plan to add this way of filtering as on option directly in FlexGrid? Most of the other js grids out there have this option. Our customers prefer it because it’s much easier to use than the complex popups, and you can easily see what filters are applied.
Posted 13 January 2020, 2:01 am EST
Hi Scott,
We are sorry but there is no plan to add HeaderFilters in FlexGrid. Our grid is based on excel and excel also does filtering by using popups. If we were to change the default filtering to the HeaderFilters, we will have to change our whole filtering design.
I hope you understand.
