Hide the entire column if it's grand total having value zero using wijmo
Posted by: mailtovashist02 on 28 June 2022, 7:22 am EST
  • Posted 28 June 2022, 7:22 am EST
    How do I hide the entire column if it’s grand total having value zero using wijmo grid angular?
    I have pivot grid where I want to hide the entire column if the grand total of that column is zero.
    Please suggest
  • Posted 29 June 2022, 5:44 am EST
    You may handle the loadedRows event of PivotGrid, check each column’s aggregate value in columnCollection, and update the visible property of the columns accordingly. Please refer to the sample link below demonstrating the same:
    https://stackblitz.com/edit/angular-pagnyj?file=src%2Fapp%2Fapp.component.html,src%2Fapp%2Fapp.component.ts
