How can I put a check box on wijmo flex grid header?
Posted by: arnoldbendaa on 31 January 2018, 10:45 pm EST
    Posted 31 January 2018, 10:45 pm EST
    I am a beginner of wijmo flex grid.
    I would like to put check box on table header.
    So I make code as following.
    var flex = $scope.ctx.flex;
                    flex.columns.push(new wijmo.grid.Column({ header: '<input type="checkbox"/>',name:'checkbox',align:'center'}));
    But I cannot see the check box.
    the code is viewing on flex grid table.
    How can I fix this bug?
  • Posted 1 February 2018, 2:31 am EST
    Please refer to the attached fiddle
    http://jsfiddle.net/Wijmo5/f07xegc1/
    Checkbox is added to Column Header by adding the HTML element when the grid is being formatted. You can do this by setting the itemFormatter .
  • Posted 1 February 2018, 5:49 am EST
    Thank you very much.
  • Posted 30 March 2020, 10:42 am EST
    Hi.
    I used exact same code but it did not work.
  • Posted 31 March 2020, 4:23 am EST
    Hi Akshay,
    Can you please let us know the exact issue? Also, please make sure that there are no errors in the browser’s console.
    If you can provide a sample replicating the issue, it would be really helpful in providing you with a solution.
