How to create an extra aggregate row in flex grid which shows sum
Posted by: rakesh.thummanapelly on 22 June 2022, 8:48 am EST
    Posted 22 June 2022, 8:48 am EST
    How to create an extra aggregate row which has sum of total items irrespective of grid filtering
  • Posted 23 June 2022, 4:49 am EST
    You may use the getAggregate() method of Wijmo to get the aggregate of the desired column irrespective of filtering and insert the value into the columnFooter row cells by handling formatItem event of FlexGrid. Please refer to the sample link below demonstrating the same:
    https://stackblitz.com/edit/js-tvnvxf?file=index.js
  • Posted 23 June 2022, 11:23 pm EST
    Hi Thanks for the response.
    Can we make the aggregate row (bottomLeft cell) clickable so that we would have a single aggregate row to toggle between showing filtered sum and Total sum.
  • Posted 24 June 2022, 8:21 am EST
    Yes, you can add a click event on FlexGrid hostElement and toggle the visible property of the bottom total row. Please refer to the code snippet and sample link below demonstrating the same:
    https://stackblitz.com/edit/js-bsrcze?file=index.js
    Sonu Kumar Pandey
  • Posted 27 June 2022, 4:47 am EST
    Thank you very much !!
  • Posted 22 November 2022, 11:24 pm EST
    Hi Sonu,
    I have posted a question related to changing of flexgrid row color, can u please look into it
  • Posted 23 November 2022, 12:35 am EST
    I have answered your question regarding the flexGrid row color changing, please refer to the following thread for the same - https://www.grapecity.com/forums/wijmo/how-to-change-the-background-color-of-a-row-in-flexgrid-from-typescript
    ~Vivek Pannu
