Posted 12 June 2019, 8:50 am EST
I want an event to be triggered from wijmo flexsheet once it has completed rendering of datasource provided to it.
I am using Angular 5.
Posted by: reeshabh.choudhary on 12 June 2019, 8:50 am EST
Posted 13 June 2019, 4:12 am EST
You may use the initialized or the loadedRows event. Please refer to the code snippet below that shows how you can use these events:
In your markup:
<wj-flex-sheet #sheet (initialized)="initSheet(sheet)" (loadedRows)="loadedRows(sheet, $event)>
In your TS file:
initSheet(sheet) {
// your code
loadedRows(sheet, args) {
// your code
You may use any one of the events for your use case.
