How to implements flex grid sorting in Angular 2+
Posted by: rajesh.sakhamuri on 26 February 2020, 8:45 am EST
  • Posted 26 February 2020, 8:45 am EST
    I am using Wijmo flex grid , When i click on the arrow indicater (▲) in grid column, then only sorting is happening. But click on other place in grid column header, sorting is not happening.
    <wj-flex-grid-column header=“Account Name” binding=“accountName” [wordWrap]=true [minWidth]=120 [maxWidth]=120>
    Can you please help on this issue…
  • Posted 27 February 2020, 1:00 am EST
    Hi Rajesh,
    We are sorry but we were unable to replicate the issue at our end. Please refer to the sample link below that we used to replicate the issue:
    https://stackblitz.com/edit/angular-ns3qdu
    Can you please modify the sample so that it replicates the issue?
  • Posted 27 February 2020, 1:43 am EST
    Hi Ashwin,
    I am using same code like above you have provided, but i don’t no why it’s not working.
    Scenario: When i have click on the arrow indicator (▲) symbol in grid column header, then only sorting is happening, but when i clicking on the other place in same column header, sorting is not working.
    <wj-flex-grid #flex [headersVisibility]=“‘Column’” [(itemsSource)]=“dataItems”
    [allowDragging]=“‘None’” [allowResizing]=“‘None’” [isReadOnly]=true>
    <wj-flex-grid-column header="EmployeeName" binding="employeeID" [wordWrap]=true [minWidth]=110 [maxWidth]=110>
      </wj-flex-grid-column>
  • Posted 27 February 2020, 11:51 pm EST
    Hi Rajesh,
    Can you please check whether there is any error thrown in the console after clicking on the header? Also, which version of Wijmo are you using? Have you added any other click or mousedown handlers on the FlexGrid?
  • Posted 28 February 2020, 9:56 am EST
    Hi Ashwin,
    There is no console errors, while doing sorting and i didn’t add any event handlers on the grid.
    I have observed when i am doing sorting , two times the sorting event happening while debugging. that’s way every time it will be the same mode.
    Please tell me how to avoid, two times sorting when clicking once…
  • Posted 29 February 2020, 9:01 am EST
    Hi Ashwin / Team,
    Any update on this issue…?
  • Posted 2 March 2020, 8:00 am EST
    Hi Rajesh,
    Sorry for the late response.
    To further investigate the issue, we will require a sample replicating the issue. Can you please modify the sample provided earlier accordingly? If you will start to modify the sample, it may also help you to identify the cause of the issue.
