How to make possible to cut in FlexGrid (with shortcut CTRL + X)
Posted by: bozjator on 11 November 2019, 11:42 am EST
    Posted 11 November 2019, 11:42 am EST
    is there a way to enable cutting (with CTRL + X) in the FlexGrid, the same way i can copy by CTRL + C?
  • Posted 13 November 2019, 3:21 am EST
    You will need to handle the ‘keyup’ event of the FlexGrid and then cut the data from the FlexGrid:
    grid.hostElement.addEventListener('keyup', function(e) {
      if(e.ctrlKey && e.key === 'x') {
        const data = grid.getClipString();
        wjcCore.Clipboard.copy(data);
        grid.setClipString('');
    }, true)
    You may refer to the sample link below:
    https://stackblitz.com/edit/js-brssdp
    Please note that if a column is required (number and date types column are required by default), then the data of that column will not be removed from the FlexGrid.
