How to override select all functionality of Selector class in Flexgrid?
Posted by: abhijeet.dey on 17 September 2024, 5:30 am EST
    Posted 17 September 2024, 5:30 am EST
    Hi Team,
    We are using FlexGrid with Selector class. We want to override the select all functionality of selector class, since we want to select only some rows instead of all.
    I see FlexGrid class has a function called selectAll: https://developer.mescius.com/wijmo/api/classes/Wijmo_Grid.Flexgrid.html#selectall
    Which can be overriden
    But this does not affect the Selector class select all checkbox. How do we override the select all checkbox functionality ?
    https://developer.mescius.com/wijmo/api/classes/Wijmo_Grid_Selector.Selector.html
  • Posted 18 September 2024, 8:09 am EST
    Hi Abhijeet,
    You may customize the selector checkboxes by using the FormatItem event.
    For reference, Please check to the attached sample application. In the attached sample, I am using a datafield CanSelect to allow some checkboxes to be checked and some to be unchecked.
    I hope it helps!
    FlexGridPureJsCheckBoxSelection.zip
  • Posted 18 September 2024, 10:06 am EST
    So basically the select all will select all checkboxes but after that formatItem event will uncheck the ones which we don’t want, correct?
  • Posted 19 September 2024, 12:21 am EST - Updated 19 September 2024, 6:05 am EST
    Hi Abhijeet,
    Yes, You can also handle onSelectionChanging and cancel the selection if canSelect is false.
    Sample Code:
      function OnSelectionChanging(e)
        return  theGrid.rows[e.row].dataItem.canSelect;
  • Posted 19 September 2024, 4:51 am EST
    Hi Akshay,
    The link you gave is 404 but the solution works for me. Although I think this could be a future feature for the Selector class itself where we can override the default functionality. What do you think?
  • Posted 19 September 2024, 6:06 am EST
    Hi Abhijeet,
    Here’s the updated link: https://developer.mescius.com/wijmo/api/classes/Wijmo_Grid.Flexgrid.html#onwbrselectionwbrchanging
    I have updated the link in my previous reply as well.
  • Posted 25 September 2024, 5:28 am EST
    Hi Akshay,
    So the solution with onSelectionChanging works for us. But there is one problem with this solution.
    Since we are not selecting all rows, the select all checkbox in the ColumnHeader row is not getting checked, which is correct behavior.
    But the problem with this is that now the user can’t click on the select all checkbox again to un-select all items, because it is never checked.
    Is there a way to force the select all checkbox be checked even though all rows are not selected ?
  • Posted 26 September 2024, 3:01 am EST
    Hi Abhijeet,
    I’d suggest you to check out the previously shared sample again. In that sample I have also implemented the formatItem event in which whenever the checkbox’s state is indeterminate the checkbox’s checked is set as true. So whenever you click on the select all checkbox in the ColumnHeader row it would act as all rows are selected.
    Code snippet:
    theGrid.formatItem.addHandler((s, e) => {
        if (e.panel.cellType == CellType.TopLeft) {
          if (e.cell.firstChild)
            if (e.cell.firstChild.firstChild.indeterminate) {
              e.cell.firstChild.firstChild.checked = true;
  • Posted 23 December 2024, 6:36 am EST - Updated 23 December 2024, 7:06 am EST
    Hi Akshay
    I apologize for the late reply, this snippet worked for me
    if (event.panel.cellType === CellType.ColumnHeader && event.col === 0) {
    const selectAll = event.cell.querySelector(‘input.wj-column-selector-group’) as HTMLInputElement;
    if (selectAll) {
    if (selectAll.indeterminate) {
    selectAll.checked = true;
    But I still don’t see the checked symbol on the select all checkbox after checked property is set to true, what am I missing here? (See attached video in zip)select-all.zip
    I see that there is a :after pseudo element added to input tag if we click manually, but if set checked property to true, it is not added
    Edit: I fixed it by setting indeterminate to false also
  • Posted 24 December 2024, 7:24 am EST
    Hi Abhijeet,
    Thank you for sharing this information. We are glad that the issue is resolved now. In case, you face any other issues, please let us know.
