Posted 6 October 2021, 9:05 pm EST
hello.
how to refresh multi-select control wjTooltip property contents?
<wj-multi-select #master [wjTooltip]=“‘#tooltip’”>
- {{ item.value }}
Posted by: jungdh on 6 October 2021, 9:05 pm EST
hello.
Posted 7 October 2021, 12:23 pm EST
It appears like the changes are not getting detected by the tooltip, this seems like a bug we have escalated the issue to our Dev team for further investigation with an internal tracking ID WJM-21122. We will update you on this as soon as we get any updates.
Sorry, for the inconvenience.
Posted 11 October 2021, 9:31 pm EST
sonu.pandey sir.
Posted 23 December 2022, 9:06 am EST
sonu.pandey.
WJM-21122 complated?
Posted 26 December 2022, 1:49 am EST
We apologize for the delay, as per Dev’s wjTooltip works with static content only, so this is a limitation. It takes its own content at Tooltip.setTooltip method call and shows that content without changing until the method is called again on the same element.
However, as a workaround, you can handle the checkedItemsChanged event of MultiSelect as shown in the below sample link:
https://stackblitz.com/edit/angular-fur78t?file=src%2Fapp%2Fapp.component.ts
Thank you for your patience.
