How to remove row of FlexGrid when scroll row below column header
Posted by: danquyen6596 on 8 February 2022, 6:49 am EST
    Posted 8 February 2022, 6:49 am EST - Updated 3 October 2022, 12:07 pm EST
    I making flexgrid have set background-corlor of column header transparent.
    result in picture. Fix error?
    Thanks!
  • Posted 9 February 2022, 1:36 pm EST
    We are unable to understand the issue here. The shared image doesn’t provide much information, could you please share a clear image and detailed information on the issue/error you are facing? so that we can assist you accordingly.
    If you wish to set the background color of the FlexGrid to transparent then you may use the CSS given below:
    .wj-header{
        background-color: transparent !important;
  • Posted 15 February 2022, 4:41 am EST
    We are sorry but in the case of the transparent header, the observed issue is expected because the top row which is partially visible get behind the header cells.
    Instead of having a transparent background, I would suggest you have the header color same as its background.
