Posted 29 April 2024, 3:28 am EST
Hi Wijmo team,
https://stackblitz.com/edit/angular-pm5nse?file=src%2Fapp%2Fapp.component.ts
Need one help in above snippet, I need to put some extra conditions if I try to select ‘test’ from Section column then in corresponding **Subjects column **‘All’ keyword should be disabled and I should be only allowed to select one element from Subject dropdown(multiselection should be avoided if I select ‘test’ value from Section dropdown), same should also happen for sub-subjects column too…
