How to set checkbox state of TreeView?
Posted by: fejlesztes on 16 January 2018, 12:32 pm EST
    Posted 16 January 2018, 12:32 pm EST
    I’m using the WjTreeView with Vue and I want to initialize the tree with some items checked by default.
    How can I do this?
  • Posted 17 January 2018, 2:11 am EST
    For this, you need to get the node to be checked and use setChecked method for TreeNode in initialized event. Please use the following code snippet and attached sample for the same:
    var node=treeView.getNode(treeView.nodes[0].dataItem.items[2].items[0]);
                    node.setChecked(true,true);
                node=treeView.getNode(treeView.nodes[0].dataItem.items[3].items[1]);
    ~Manish
    TreeView_checkNode.zip
  • Posted 28 September 2020, 8:05 am EST
    I want to restore the check boxes like this
    tree.checkedItems = ; //result array of tree.checkedItems
    it is not working and i dont want to manually set check boxes checked
  • Posted 29 September 2020, 6:20 am EST
    Hi Mobeen,
    You can use the checkAllItems method of the TreeView to set all the nodes as checked or unchecked.
    API: https://www.grapecity.com/wijmo/api/classes/wijmo_nav.treeview.html#checkallitems
  • Posted 5 October 2020, 5:54 am EST
    Hi Manish,
    In angular I implemented TreeView, on page loads i have to enable checkbox checked by default , but not all checkboxes, you can see my json data will be like this var items = [
    { header: ‘Electronics’,showChecked:true, items: [
    { header: ‘Trimmers/Shavers’,showChecked:true },
    { header: ‘Tablets’,showChecked:false },
    { header: ‘Phones’,showChecked:false, items: [
    { header: ‘Apple’,showChecked:false },
    { header: ‘Motorola’,showChecked:false },
    { header: ‘Nokia’,showChecked:false },
    { header: ‘Samsung’,showChecked:false }
    {header:‘LapTop’,showChecked:true,items:[
    {header:‘Dell’,showChecked:false},
    {header:‘Lenovo’,showChecked:true}
    { header: ‘Speakers’,showChecked:false },
    { header: ‘Monitors’,showChecked:false }
    { header: ‘Toys’,showChecked:false, img: ‘resources/toys.png’, items: [
    { header: ‘Shopkins’ ,showChecked:false},
    {header:‘Train Sets’,showChecked:false},
    {header:‘Science Kit’,showChecked:false},
    {header:‘Play-Doh’,showChecked:false},
    {header:‘Crayola’,showChecked:false},
    { header: ‘Home’,showChecked:true, img: ‘resources/home.png’}
    where showChecked is true, that particular checkbox should be checked by default on component load, I have tried by using above code which you have mentioned, but it is not working in my case, will plz suggest me any other alternative solution for this.
  • Posted 5 October 2020, 11:46 pm EST
    Hi Gowri,
    You may use the checkedMemberPath property of the TreeView and assign its value to ‘showCheckbox’. This property is used to bound the checkbox state of the item to a property in the data item.
    API: https://www.grapecity.com/wijmo/api/classes/wijmo_nav.treeview.html#checkedmemberpath
  • Posted 8 October 2020, 3:08 am EST
    Hi Ashwin,
    Thank you so much for suggesting me, its working.
    regards,
    Gowri.
