How to show scroll horizontal by condition in flexgrid wijmo
Posted by: viethdhe130200 on 25 October 2022, 12:02 am EST
  • Posted 25 October 2022, 12:02 am EST - Updated 25 October 2022, 12:02 am EST
    I want to show scroll horizontal from the 4th position column onwards because in the first 3 columns I used frozenColumns={3}.
    So in flex grid wijmo is there any property that I can set to display horizontal scroll from the 4th column onwards (do not show scroll horizontally in the first 3 columns in the table)
    I hope anyone helps me in this case. Thank you very much!!!
  • Posted 25 October 2022, 12:03 am EST
    My code:
    [code]componentDidMount() {
    const { listClassesOfSchool1, listClassesOfSchool2, listClassesOfSchool3, listClassesOfSchool4 } = this.state;
    const listData = dataFake.data.entities.field_work_types;
    const listItems = ;
    listData.forEach(item => {
    listItems.push({
    classId: item.classId,
    className: item.className,
    majorId: item.majorId,
    majorName: item.majorName,
    isIncludeInstance: false,
    listClass1: listClassesOfSchool1,
    listClass2: listClassesOfSchool2,
    listClass3: listClassesOfSchool3,
    listClass4: listClassesOfSchool4,
    this.setState({ listItems: new CollectionView(listItems) });
    handleCheckBox = (isChecked, id) => {
    const listClasses = […this.state.listClasses];
    listClasses[id].isChecked = isChecked;
    this.setState({
    listClasses
    render() {
    const { listItems, listClasses, listClassesOfSchool1, listClassesOfSchool2, listClassesOfSchool3, listClassesOfSchool4 } = this.state;
    return (
    {listClasses.map(item => {
    return (
    <input type=‘checkbox’ name=‘checkbox’ checked={item.isChecked} onChange={e => this.handleCheckBox(e.target.checked, item.id)} /> {item.name}
    <FlexGrid
    autoGenerateColumns={false}
    itemsSource={listItems}
    frozenColumns={3}
    headersVisibility=‘Column’
    allowSorting={false}
    allowDragging={0}
    initialized={this.initialDataGrid}
    quickAutoSize={true}
    <FlexGridColumnGroup
    header=‘Class’
    cssClassAll={‘wj-align-center’}
    header=‘Name’
    binding=‘className’
    isReadOnly={true}
    header=‘Major’
    binding=‘majorName’
    isReadOnly={true}
    {listClasses[0].isChecked && (
    header={listClasses[0].name}
    visible={false}
    {listClassesOfSchool1.map((item, index) => {
    return (
    header={item.name}
    binding={
    listClass1[${index}].name
    isReadOnly={true}
    cssClassAll={
    ‘wj-align-center’
    {listClasses[1].isChecked && (
    header={listClasses[1].name}
    visible={false}
    {listClassesOfSchool2.map((item, index) => {
    return (
    header={item.name}
    binding={
    listClass2[${index}].name
    isReadOnly={true}
    cssClassAll={
    ‘wj-align-center’
    {listClasses[2].isChecked && (
    header={listClasses[2].name}
    visible={false}
    {listClassesOfSchool3.map((item, index) => {
    return (
    header={item.name}
    binding={
    listClass3[${index}].name
    isReadOnly={true}
    cssClassAll={
    ‘wj-align-center’
    {listClasses[3].isChecked && (
    visible={false}
    {listClassesOfSchool4.map((item, index) => {
    return (
    header={item.name}
    binding={
    listClass4[${index}].name
    isReadOnly={true}
    cssClassAll={
    ‘wj-align-center’
    }[/code]
  • Posted 27 October 2022, 4:32 am EST
    Sorry, but it wouldn’t be possible to achieve the behavior due to the FlexGrid design architecture. Sorry for the inconvenience.
