Posted 31 August 2020, 12:37 am EST
Hi Chhavi,
If you only need to display in UTC date, then you may use the formatItem event to convert the date value to UTC and change the innerHTML of the cell so that the UTC date is displayed. Note that the if you will use filtering along side this method, the FlexGridFilter will still display the original non-UTC dates.
If you need to update the underlying data. then simply iterate over each item in FlexGrid and convert the data to UTC.
Please refer to the sample link below for reference:
https://stackblitz.com/edit/angular-dgnxxh
