How to word wrap two line in column header flex grid?
Posted by: ramu on 4 December 2017, 6:25 am EST
    Posted 4 December 2017, 6:25 am EST
    I have used Wijmo 5.20171.282 version.
    I want to word wrap two line or more line in column header text using flex gird.
    <wj-flex-grid-column [header]="'Employer Start Date'" [binding]="'StartDate'" width="30*" wordWrap="true">
  • Posted 4 December 2017, 7:25 am EST
  • Posted 5 December 2017, 3:06 am EST
    The above link is not working. It says “404 Page Not Found”
  • Posted 5 December 2017, 5:26 am EST
    Thanks Abhishek.
    I did manually copied the url and paste. It works.
    Once added below lines. It works as I am expected.
    ///// CSS
    .wj-header{
                white-space: pre-wrap !important;
    //// Script
    // resize column header
    flex.autoSizeRow(0,true)
    flex.autoSizeRow(1,true)
    flex.autoSizeRow(2,true)
    flex.autoSizeRow(9,true)
    But I have 10 column in the grid. So I want to added 10 times those line. Is any other option to avoid this?
    Ramu
  • Posted 6 December 2017, 5:51 am EST
    Hi Ramu,
    You can call autoSizeRows or autoSizeColumns method for auto sizing all rows and columns once.
    flex.autoSizeRows();
    flex.autoSizeColumns();
    ~Manish
  • Posted 9 March 2018, 12:36 pm EST
    I simply did this and it worked.
      <wj-flex-grid-column binding="longDescription" [width]="100" [wordWrap]="true">
                <ng-template wjFlexGridCellTemplate cellType="ColumnHeader">
                    <span style="word-wrap: break-word;">Long Description Goes here</span>
                </ng-template>
            </wj-flex-grid-column>
  • Posted 30 November 2019, 7:55 am EST
    Did you have to do it for every column?
  • Posted 2 December 2019, 12:12 am EST
    Hi Mark,
    If you wish to wrap the headers of only some of the columns, then you will need to add the code above for each of these columns. But, if you wish to wrap the headers of all the columns, then you can use the formatItem event instead of cell template:
    https://stackblitz.com/edit/angular-gs7sa7
  • Posted 5 November 2020, 3:04 am EST
    [b]Hi,
    I am using Wijmo version 5.20191.612
    I want to word wrap my column header to two or more line using flex gird. I used the below code but still it is not working.[/b]
    <wj-flex-grid-column [header]=“‘Service Partner Branch Details’” [binding]=“‘ServicePart’” width=“30*” wordWrap=“true”>
    ///// CSS
    .wj-header{
    //// Script
    Can you please help to resolve this issue.
  • Posted 5 November 2020, 2:17 pm EST
    You need to provide the wordWrap property inside square brackets (and width too):
    <wj-flex-grid-column [header]="'Service Partner Branch Details'" [binding]="'ServicePart'" [width]="'30*'" [wordWrap]="true">
