I'd like to copy and paste vertical lines
Posted by: minjaekm.kim on 6 December 2022, 8:59 pm EST
  • Posted 6 December 2022, 8:59 pm EST
    https://www.grapecity.com/wijmo/demos/Grid/TreeGrid/ChildItems/react
    The source on this page has been modified.
    import "@grapecity/wijmo.styles/wijmo.css";
    import "bootstrap.css";
    import "./app.css";
    import * as React from 'react';
    import * as ReactDOM from 'react-dom';
    import { FlexGrid, FlexGridColumn } from "@grapecity/wijmo.react.grid";
    import { getFamilies, getWorkers } from "./data";
    class App extends React.Component {
        constructor(props) {
            super(props);
            this.state = {
                showAsTree: true,
                family: getFamilies(),
                workers: getWorkers(),
        render() {
            return <div className="container-fluid">
                <FlexGrid initialized={this.initGrid.bind(this)} headersVisibility="Column" childItemsPath={['checks', 'earnings']} itemsSource={this.state.workers}>
                    <FlexGridColumn binding="name" header="Name"/>
                    <FlexGridColumn binding="hours" dataType="Number" allowSorting={false}/>
                    <FlexGridColumn binding="rate" dataType="Number" allowSorting={false}/>
                </FlexGrid>
            </div>;
        initGrid(grid) {
            this.targetSettingGrid = grid;
            this.readOnly();
        readOnly() {
            this.targetSettingGrid.rows.forEach((row) => {
                row.isReadOnly = false;
    ReactDOM.render(<App />, document.getElementById('app'));
    It works if you stick it on the app.jsx.
    Horizontal lines are copied and pasted, while vertical lines become impossible to enter into all cells once they have been made.
  • Posted 7 December 2022, 2:26 am EST
    To resolve the issue you may handle the loadedRows event of FlexGrid and set all rows’ isReadOnly property to false to make them editable again after the grid refreshes its content. Please refer to the sample link below demonstrating the same:
    https://stackblitz.com/edit/react-3vr1ga?file=index.js
