Implementing multiselect in FlexGrid
Posted by: muhammad.rifatullah on 26 June 2018, 3:56 am EST
    Posted 26 June 2018, 3:56 am EST
    I am new at wijmo. I want to implement multiselect in flexgrid using pureJS.
    For example, we have a table with user name, and his favorite fruits (this column multiselect).
    Currently I am using CustomGridEditor, but the data is not initialized and the checkedItems is applied to all row.
    Thank you very much
  • Posted 27 June 2018, 9:10 am EST
    To make the CustomGridEditor support Multiselect properly first you need to make few changes in CustomGridEditor.js.
    Please refer to following code snippet:
    Add following lines of code in _beginningEdit method
    var data=grid.getCellData(this._rng.row, this._rng.col, false);
    if((data instanceof Array)&&(this._ctl instanceof wijmo.input.MultiSelect)){
    	this._ctl.checkedItems=data;
    After this line
    this._ctl['text'] = grid.getCellData(this._rng.row, this._rng.col, true);
    Then in _closeEditor method change these lines
    if (!wijmo.isUndefined(ctl['value'])) {
    	this._grid.setCellData(this._rng.row, this._rng.col, ctl['value']);
    else if (!wijmo.isUndefined(ctl['text'])) {
    	this._grid.setCellData(this._rng.row, this._rng.col, ctl['text']);
    With following lines
    if(this._ctl instanceof wijmo.input.MultiSelect){
    	this._grid.setCellData(this._rng.row, this._rng.col, ctl.checkedItems);
    else if (!wijmo.isUndefined(ctl['value'])) {
    After making the required changes it should work fine.
    Please refer to following sample for the same:-
    https://stackblitz.com/edit/js-3iesr9-ttgc3w?file=index.js
    ~Manish
  • Posted 28 June 2018, 2:59 am EST
    Thank you very much.
    What if the products are array of object?
    I try, but in cell data, it outputs the object, not the value of selectedValuePath.
  • Posted 28 June 2018, 3:07 am EST
    Btw, still, in your example, https://stackblitz.com/edit/js-3iesr9-ttgc3w?file=index.js, if you change the value, it will be implemented to another value. to reproduce please follow the following scenario;
    1. change selected products of row 1,.
    2. change selected products of another row, ex 3. see row 1.
    3. change selected products of another row again, ex 5. see row 1 and 3.
  • Posted 29 June 2018, 11:20 am EST
    We are indeed sorry for the issue in the last sample. We can fix that by assigning new array for each individual data cell.
    In _closeEditor method replace this code
    //with following
    this._grid.setCellData(this._rng.row, this._rng.col, ctl.checkedItems.map(item=>item));
    For adding support for an array of object we need few more minor adjustments.
    First, define a function which will determine if the given objects are equal based on some condition
    function areObjectEqual(obj1,obj2){
    	/* if ref are equal objects are definitely equal
    	can also compare value types */
    	if(obj1===obj2){
    		return true;
    	for(let key in obj1){
    		if(obj1[key]!=obj2[key]){
    			return false;
    	return true;
    //then in _beginningEdit method instead of assigning the data from grid directly to multiselect first create a new array of objects that contains the values from grid then assign it to multiselect.checkedItems
    //if multiselect
    	var checked=[];
    	data.forEach(dataItem=>{
    		for(let item of this._ctl.itemsSource){
    			if(areObjectEqual(dataItem,item)){
    				checked.push(item);
    				break;
    	this._ctl.checkedItems=checked;
    Finally to display the array of objects into grid’s cell you need to handle the formatItem event and convert the array to the required display string value:-
    grid.formatItem.addHandler((s,e)=>{
    	if(e.panel!=s.cells||e.editRange){
    		return;
    	if(s.columns[e.col].binding!="products"){
    		return;
    	var dataItem=s.rows[e.row].dataItem.products;
    	var displayString=dataItem.reduce((acc,curr)=>{
    		if(acc){
    			return acc+","+curr.value;
    		}else{
    			return curr.value;
    	e.cell.innerHTML=displayString;
    Please refer to the following updated sample and let us know if you still face any issues:-
    https://stackblitz.com/edit/js-3iesr9-kfqjmy?file=index.js
    ~Manish
  • Posted 2 July 2018, 12:57 am EST
    Thank you very much!
  • Posted 31 October 2022, 3:22 am EST - Updated 31 October 2022, 5:23 am EST
    Hi~ there
    I`m using FlexGrid in Multi Select Combo overriding flexgrid getCellData function.
    I hope fully support multi Select in wijmo (FlexGridSearch, FlexGridFilter …)
    Like this.
    // For using Multi Select - Override getCellData function
    // Pure javascript
    // Wijmo-5.20221.857
    //1. Set Custom column editor.
    theGrid.getColumn("ROLE_ID").editor = new wijmo.input.MultiSelect(document.createElement('div'));
    theGrid.getColumn("ROLE_ID").editor.displayMemberPath = 'ROLE_NM';  //jsondata Code Name key
    theGrid.getColumn("ROLE_ID").editor.itemsSource = jsonData; //list of json
    //2. Copy Origin getCellData
    theGrid.cells.getCellDataOrigin = theGrid.cells.getCellData;
    //3. Override getCellData
    theGrid.cells.getCellData = function(e, t, i) {
        let grid = this._g;
        if (grid.getColumn(t).editor instanceof wijmo.input.MultiSelect && i) {
            let displayString = '';
            if (grid.cells.getCellDataOrigin(e, t)) {
                grid.cells.getCellDataOrigin(e, t).forEach(function(item, idx) {
                    let val = (item[grid.getColumn(t).editor.displayMemberPath])||'Null';
                    displayString += (idx > 0)? ', '+val : val;
            return displayString;
        } else {
            return grid.cells.getCellDataOrigin(e, t, i)
  • Posted 1 November 2022, 5:24 am EST
    In the latest builds, you do not need to override the getCellData() method, Multiselect is supported as an editor natively. Please refer to the following sample:
    https://stackblitz.com/edit/js-6qvjzh?file=data.js,index.js,index.html
    Regarding, Multiselect support for FlexgridSearch and FlexgridFilter, we are sorry but it is not supported because Filter and search works at the data level(CollectionView) whereas editor is supported only at the presentation layer(Flexgrid).
