Posted 6 July 2020, 2:59 pm EST
In MultiSelect (wj-multi-select): showFilterInput not works
while apply [showFilter]: “true” in angular, throws error in console, a not part of ngmodule
please suggest.
Posted by: ksm.ac.in on 6 July 2020, 2:59 pm EST
please suggest.
Posted 7 July 2020, 2:15 am EST
The property is showFilterInput and not showFilter. That is why angular throws an error. You just need to update you template like this:
<wj-multi-select #ms [showFilterInput]="true"...></wj-multi-select>
Posted 7 July 2020, 6:54 am EST
sorry it is showFilterInput
i tried this one
getting same error.
Posted 7 July 2020, 7:01 am EST
i TRIED INTHE SAME WAY
<wj-multi-select #ms [showFilterInput]=“true”…>
as showFilterInput this property is not availabe in the class.
there no such property .
same error thrown and show in console
Is because any old version of it as we have 5.20191.605 versionof wijmo
Posted 8 July 2020, 1:28 am EST
The showFilterInput property was added in the 5.20201.663 version. That is why it is throwing an error because in 19v1, this property was not available.
If you need to use this, then I would suggest you upgrade wijmo to at least this version.
