Input control with invalidInput event
Posted by: rihiham148 on 17 November 2022, 12:02 am EST
    Posted 17 November 2022, 12:02 am EST
    I want my invalid input event for autocomplete/combobox, to be set in a way that as the user enters incorrect input other than text which is in display Path, then it should get fired. Also do not have any more or extra conditon for this event.
    Thanks in advance
    Arohi
  • Posted 18 November 2022, 2:54 am EST
    Hi Arohi,
    You can use the ‘onInvalidInput’ method to trigger the ‘invalidInput’ event as per your requirements. However, if you don’t want the user to enter values which are not in items of the itemsSource collection, you can set the ‘isEditable’ property of the combobox/autoComplete to false, as it will restrict the content of the input element to items in the itemsSource collection.
    Please find attached a sample for the same - https://stackblitz.com/edit/js-jnpghh?file=index.js
  • Posted 20 November 2022, 11:47 pm EST
    Here I have an issue that is whenever I enter ‘in’ for eg. In autocomplete control, then there are valid options in the drop-down but when I select Singapore in it it still shows invalid input in html and console. Kindly resolve this.
    Arohi
    Arohi
  • Posted 21 November 2022, 8:16 am EST
    To avoid this issue, you can handle the ‘textChanged’ event on the ‘autoComplete’ and ‘comboBox’ control, for checking the validation errors.
    Please refer to the following updated sample for the same - https://stackblitz.com/edit/js-g94pyd?file=index.js
  • Posted 21 November 2022, 11:12 pm EST
    This stackblitz code which you have provided is not running correctly, and also when i did the same thing it is throwing console error.
  • Posted 22 November 2022, 3:28 am EST - Updated 22 November 2022, 3:33 am EST
    Sorry, we are unable to replicate your issue on our end, as there is no such issue on our end. Please refer to the following image
    Can you please share a sample replicating your issue, with us, on which we can investigate and assist you accordingly.
