Issue for perfomance when use flexgridColumnGroup with Reactjs
Posted by: viethdhe130200 on 29 September 2022, 2:08 am EST
  • Posted 29 September 2022, 2:08 am EST
    Hi, admin wijmo. I have a problem when I use flexgridColumnGroup for dynamic render
    I have 4 checkboxes corresponding to school1, school2, school3, school4
    When I check the checkbox, it will add the number of columns corresponding to the number of items that the school has to the table
    The adding process is speedy. But when I check all 4 schools and then deselect them, it’s prolonged
    It’s link I demo in jscodemine: https://jscodemine.grapecity.com/sample/bgH1CbYvBE2-GhllEXHCjw/
    Please copy the content in the file I attached and paste it into the app.jsx on the link jscodemine (https://jscodemine.grapecity.com/sample/bgH1CbYvBE2-GhllEXHCjw/) to test it
    It’s a link to youtube I demo: https://www.youtube.com/watch?v=WCpvJ8NXhAs&ab_channel=ViệtHoàng
    I hope anyone helps me in this case. Thank you very much!!!
  • Posted 29 September 2022, 2:10 am EST
    Please copy the content and paste it into the app.jsx on the link jscodemine (https://jscodemine.grapecity.com/sample/bgH1CbYvBE2-GhllEXHCjw/) to test it:
    import ‘bootstrap.css’;
    import ‘@grapecity/wijmo.styles/wijmo.css’;
    import ‘./app.css’;
    import * as React from ‘react’;
    import * as ReactDOM from ‘react-dom’;
    import { FlexGrid, FlexGridColumnGroup } from ‘@grapecity/wijmo.react.grid’;
    import { CollectionView } from ‘@grapecity/wijmo’;
    import * as DataService from ‘./data’;
    class App extends React.Component {
    constructor(props) {
    super(props);
    this.state = {
    listClassesOfSchool1: listClasses.listClassesOfSchool1(),
    listClassesOfSchool2: listClasses.listClassesOfSchool2(),
    listClassesOfSchool3: listClasses.listClassesOfSchool3(),
    listClassesOfSchool4: listClasses.listClassesOfSchool4(),
    listItems: ,
    listClasses: [
    { id: 0, name: ‘school1’, isChecked: false },
    { id: 1, name: ‘school2’, isChecked: false },
    { id: 2, name: ‘school3’, isChecked: false },
    { id: 3, name: ‘school4’, isChecked: false }
    componentDidMount() {
        const { listClassesOfSchool1, listClassesOfSchool2, listClassesOfSchool3, listClassesOfSchool4 } = this.state;
        const listData = dataFake.data.entities.field_work_types;
        const listItems = [];
        listData.forEach(item => {
            listItems.push({
                classId: item.classId,
                className: item.className,
                majorId: item.majorId,
                majorName: item.majorName,
                isIncludeInstance: false,
                listClass1: listClassesOfSchool1,
                listClass2: listClassesOfSchool2,
                listClass3: listClassesOfSchool3,
                listClass4: listClassesOfSchool4,
        this.setState({ listItems: new CollectionView(listItems) });
    handleCheckBox = (isChecked, id) => {
        const listClasses = [...this.state.listClasses];
        listClasses[id].isChecked = isChecked;
        this.setState({
            listClasses
    render() {
        const { listItems, listClasses, listClassesOfSchool1, listClassesOfSchool2, listClassesOfSchool3, listClassesOfSchool4 } = this.state;
        return (
            <div className="container-fluid">
                {listClasses.map(item => {
                    return (
                        <div>
                            <input type='checkbox' name='checkbox' checked={item.isChecked} onChange={e => this.handleCheckBox(e.target.checked, item.id)} /> {item.name}
                        </div>
                <FlexGrid
                    autoGenerateColumns={false}
                    itemsSource={listItems}
                    frozenColumns={0}
                    headersVisibility='Column'
                    allowSorting={false}
                    allowDragging={0}
                    initialized={this.initialDataGrid}
                    quickAutoSize={true}
                    <FlexGridColumnGroup
                        header='Class'
                        cssClassAll={'wj-align-center'}
                            header='Name'
                            binding='className'
                            isReadOnly={true}
                        </FlexGridColumnGroup>
                            header='Major'
                            binding='majorName'
                            isReadOnly={true}
                    {listClasses[0].isChecked && (
                            header={listClasses[0].name}
                            visible={false}
                            {listClassesOfSchool1.map((item, index) => {
                                return (
                                        header={item.name}
                                        binding={`listClass1[${index}].name`}
                                        isReadOnly={true}
                                        cssClassAll={
                                            'wj-align-center'
                    {listClasses[1].isChecked && (
                            header={listClasses[1].name}
                            visible={false}
                            {listClassesOfSchool2.map((item, index) => {
                                return (
                                        header={item.name}
                                        binding={`listClass2[${index}].name`}
                                        isReadOnly={true}
                                        cssClassAll={
                                            'wj-align-center'
                    {listClasses[2].isChecked && (
                            header={listClasses[2].name}
                            visible={false}
                            {listClassesOfSchool3.map((item, index) => {
                                return (
                                        header={item.name}
                                        binding={`listClass3[${index}].name`}
                                        isReadOnly={true}
                                        cssClassAll={
                                            'wj-align-center'
                    {listClasses[3].isChecked && (
                            visible={false}
                            {listClassesOfSchool4.map((item, index) => {
                                return (
                                        header={item.name}
                                        binding={`listClass4[${index}].name`}
                                        isReadOnly={true}
                                        cssClassAll={
                                            'wj-align-center'
                </FlexGrid>
            </div>
    export const listClasses = {
    listClassesOfSchool1() {
    const arr = ;
    for (let i = 0; i < 250; i++) {
    arr.push({ id: i, name:
    item${i}
    return arr;
    listClassesOfSchool2() {
    const arr = ;
    item${i}
    return arr;
    listClassesOfSchool3() {
    const arr = ;
    item${i}
    return arr;
    listClassesOfSchool4() {
    const arr = ;
    item${i}
    return arr;
    export const dataFake = {
    result: true,
    status: 0,
    message: ‘’,
    data: {
    total: 2,
    entities: {
    field_work_types: [
    classId: 1,
    className: ‘main 1’,
    majorId: 1,
    majorName: ‘sub 1’,
    school1: ,
    school2: ,
    school3: ,
    school4: ,
    ReactDOM.render(, document.getElementById(‘app’));
  • Posted 3 October 2022, 4:38 am EST
    Sorry for the delayed response, we are able to replicate the issue at our end has escalated the issue to our Dev team for further investigation with an internal tracking ID WJM-24921. We will provide you an update as soon as we get a response.
