Line symbols in Date/Time line chart is not aligned with the axis ticks
Posted by: Yifan_Zhang on 9 July 2020, 1:29 pm EST
    Posted 9 July 2020, 1:29 pm EST
    Here is an example: https://jsfiddle.net/7u8y1ct9/
    You can see that the line symbols seems to be shifted leftwards and not aligned with the axis ticks. Can you help with this issue?
  • Posted 10 July 2020, 2:25 am EST
    Hi Yifan,
    Thank you for reporting the issue. I have forwarded this to the developers with internal tracking id 444935. I will update you once this issue is fixed.
  • Posted 11 July 2020, 3:17 am EST
    Thanks. Looking forward to the fix.
  • Posted 28 July 2020, 3:50 am EST
    Hi Yifan,
    The issue has been fixed in the latest nightly build of Wijmo. You may verify the same using the sample link below:
    https://stackblitz.com/edit/js-zmrmaa
    This fix will be included in the next stable release.
    PS: Nightly builds have not passed through the QA cycles as all of our release builds do. So, it is not recommended to use nightly builds in production.
  • Posted 28 July 2020, 1:16 pm EST
    Thanks for the fix. That really helps. Can’t wait for the next stable release.
