Posted 18 January 2023, 11:21 am EST
Hi
I was wondering if there is a way to make the whole row drag-able?
Currently we have the row dragging enabled but you can only reorder if you drag from the first grey column.
Posted by: davidmartin-bennett on 18 January 2023, 11:21 am EST
Hi
Posted 19 January 2023, 12:04 am EST
To drag and drop rows from any cell, you will need to make the cells draggable by using the itemFormatter property of FlexGrid and setting the cell’s draggable property to true. Then, you may handle the various drag events on the hostElement of the FlexGrid. Please refer to the sample link below for reference:
https://stackblitz.com/edit/angular-kyrwek?file=src%2Fapp%2Fapp.component.ts
Posted 19 January 2023, 5:58 am EST
That’s almost perfect, I don’t suppose there’s a way to make the dragging preview the whole row rather than just the cell you dragged?
Posted 20 January 2023, 3:21 am EST
Yes, you can show the entire row content while dragging the row. To achieve the desired result you may set the cell’s parent element(current selected row) to draggable instead of cells in the itemFormatter callback function. Please refer to the sample link below demonstrating the same:
https://stackblitz.com/edit/angular-enwryh?file=src%2Fapp%2Fapp.component.ts
Posted 20 January 2023, 4:24 am EST
Perfect, thank you
