Master-Detail for Multirow Grid
Posted by: mgorelov on 28 March 2020, 4:22 pm EST
  • Posted 28 March 2020, 4:22 pm EST
    I’m trying to utilize Master-Detail with Multirow Grid for Angular application, but it doesn’t seem to work. The grid displays fine, but detail row doesn’t expand.
    Here is my code:
    <wj-multi-row [itemsSource]="tasks" [autoGenerateColumns]="false" [layoutDefinition]="tasksLayout">
        <ng-template wjFlexGridDetail [maxHeight]="250" let-item="item">
            <wj-flex-grid [itemsSource]="item.tasks" [isReadOnly]="true" [headersVisibility]="'Column'"></wj-flex-grid>
        </ng-template>
    </wj-multi-row>
    Can somebody point me what I’m doing wrong? Or this is not supported at the moment?
  • Posted 30 March 2020, 5:31 am EST
    The FlexGridDetailProvider is not supported with MultiRow directly. But, you can customize the MultiRow and add some event listeners to add the support of details.
    First, set the detailVisibilityMode of wjFlexGridDetail to Code so that the plus and minus icons are hidden:
    <ng-template
        detailVisibilityMode="Code"
        #detail="wjFlexGridDetail"
        wjFlexGridDetail
        let-item="item"
        {{item.product | json}}
      </ng-template>
    Then, handle the formatItem event of Multirow and add the icons manually:
    onFormat(s: wjcGridMultiRow.MultiRow, e) {
        if (s.rowHeaders === e.panel) {
          var lastBindRow = e.row + (e.row % s.rowsPerItem) - 1;
          if (lastBindRow === e.row) {
            if (this.detail.isDetailVisible(e.row)) {
              e.cell.innerHTML =
                '<span class="wj-glyph-minus wj-detail-glyph"></span>';
            } else {
              e.cell.innerHTML =
                '<span class="wj-glyph-plus wj-detail-glyph"></span>';
    And then handle the mousedown event and hide/show the details as per the event data:
    multirow.rowHeaders.hostElement.addEventListener(
          "mousedown",
          e => {
            if (wjcCore.hasClass(e.target as HTMLElement, "wj-detail-glyph")) {
              var hti = multirow.hitTest(e);
              if (this.detail.isDetailVisible(hti.row)) {
                this.detail.hideDetail(hti.row);
              } else {
                this.detail.hideDetail();
                this.detail.showDetail(hti.row);
          true
    Please refer to the sample link below for reference:
    https://codesandbox.io/s/angular-5xwtr
