Memory leak caused by wj-menu-item (Angular)
Posted by: mark.brodziak on 26 November 2025, 6:24 pm EST
  • Posted 26 November 2025, 6:24 pm EST
    I’ve discovered a memory leak that appears to come from wj-menu-item. This isn’t properly disposed and is holding retainers that are keeping our component instances in memory. I know that it is this component because the leak does not present when using the programmatic Menu binding.
    Whilst I haven’t yet had time to create a minimal reproduction of this, I expect it should be fairly straightforward to spot.
  • Posted 27 November 2025, 4:34 am EST
    Hi Mark,
    We are assuming that you are working on an Angular project.
    We have forwarded this issue to the engineering team for further investigation with internal tracking ID - WJM-37372. We will share an update when we have an update from the engineering team on the same.
