Multi Select combo box custom filter in wijmo
Posted by: ganga on 14 September 2017, 11:31 am EST
    Posted 14 September 2017, 11:31 am EST
    Can some one provide sample code for Multi Select combo box custom filter for odata
  • Posted 14 September 2017, 11:31 am EST
    It seems that you are looking forward to apply multi select combobox filter to a FlexGrid which is bound using the ODataCollectionView. You can achieve the same by applying the FlexGridFilter to FlexGrid. Kindly refer to the attached sample which implements the same.
    Run the attached sample application and switch to the “Employees” tab. You can observe that a filter dropdown is set for every column. You can open the dropdown list to select multiple values and filter the FlexGrid accordingly.
    Hope it helps. Please let us know in case you are referring to a different scenario.
    Manpreet Kaur
    I am using view model for my application so I can not apply Flexgridfilters as Flexgridfilters look for specific tables where viewmodel is collection of properties from different tables .I have to come up with my own filters .Any how I created my custom filters .I have a different question ,How can we handle view models in Odata with wijmo .
    Thanks for the code .It is helpful for me .
    I found the answer to my question from the source code .I can use wijmo.grid.DataMap …Thanks for the help
  • Posted 27 April 2020, 4:48 am EST
    https://www.grapecity.com/forums/wijmo/multi-select-combo-box-cus_2#wijmoarchivehelloit-seems-
    Can you please share code to implement multiselect combo box with search option for editable cell…
    I am new wijmo grid and i am facing difficulty to implement it
  • Posted 28 April 2020, 12:32 am EST
    Hi Megha,
    You can use the filter property of the CollectionView to filter out items according to the MultiSelect’s checkedItems. Please refer to the sample below and let us know whether this is your requirement:
    https://stackblitz.com/edit/angular-88xwpv
  • Posted 28 April 2020, 9:00 am EST
    HI i tried to add custom dropdown in wijmo grid cell but my dropdown is opening inside a cell.
    I tried to change z-index but nothing works.
  • Posted 29 April 2020, 1:58 am EST
    Hi Megha,
    Can you let us know your exact requirements, because the thread is for a different issue and it seems that your issue is different.
    Also, you can use the DataMap class to add drop-downs to the FlexGrid cells:
    https://www.grapecity.com/wijmo/demos/Grid/Columns/DataMaps/angular
  • Posted 29 April 2020, 2:09 am EST
    I want to add multiselect search dropdown in the cell.
  • Posted 29 April 2020, 2:11 am EST - Updated 3 October 2022, 1:22 pm EST
    i want to create something like this.
  • Posted 30 April 2020, 12:13 am EST
    Hi Megha,
    Please refer to the sample link below:
    https://stackblitz.com/edit/angular-1eburv
    In this sample, I have added MultiSelect inside a cell using cell templates and bound its checkedItems property to the cell.value attribute.
  • Posted 30 April 2020, 6:44 am EST
    Hi Ashwin, Thank you for the solution but as i need to add search and all option i created custom dropdown in seprate componenet.
    and add it wijmo cell like below
     <ng-template *ngIf="gridInput.storeActionForMultiDropdown" wjFlexGridCellTemplate [cellType]="'Cell'" let-item="item" let-cell="cell">
                        <mat-select-search [dropdownList]="gridInput.dropdownGridData['shipMethod']" [storeAction]="gridInput.storeActionForMultiDropdown"></mat-select-search>
           </ng-template>
    but this is not working correclty if i am changing value in one dropdown that is affecting other as well and sometimes dropdown diappears.
  • Posted 1 May 2020, 1:13 am EST
    Hi Megha,
    It seems that there is some implementation issue. But to assist you further, I will need to look into the mat-select-search component. Can you provide its implementation?
  • Posted 3 May 2020, 2:23 am EST
    Hi Ashwin,
    I completed it issue was, my cell was editable so i set it readonly.
