Multiple axis with multiple series and combining lines/histograms: error
Posted by: jordi.rierababures on 4 December 2019, 12:50 pm EST
  • Posted 4 December 2019, 12:50 pm EST - Updated 3 October 2022, 6:32 pm EST
    We are using two axis on our graphics, with several series on each one. For instance (3 first series on left, 3 others on right) :
    However, when we mix histogram/line representation for some series, the graphic is sometimes corrupted, wrongly superposing the data. For the same example as above, the only change made is that the first series on the right axis is now in line format:
    I would like to know is this is a know bug and if there is some workaround it.
    Thanks in advance.
  • Posted 5 December 2019, 2:55 am EST
    Hi Jordi,
    This looks like a bug. We have forwarded a bug report to the dev team with internal tracking id 409371. We will update you as soon as the issue is fixed.
  • Posted 15 December 2019, 11:30 pm EST
    Hi Jordi,
    The issue has been fixed in the latest nightly build of wijmo. You may verify the same using the sample below:
    https://stackblitz.com/edit/js-yog94q
    PS: Nightly builds have not passed through the QA cycle as all of our release builds do. Therefore, they are not suitable in a production environment.
  • Posted 16 December 2019, 4:31 am EST
    Thank you very much for your quick reactivity.
