Multiples Y axis with different colors
Posted by: lucas.gagneten on 6 May 2019, 3:17 pm EST
    Posted 6 May 2019, 3:17 pm EST
    Hello.
    I have a Linear FlexChart with multiples Y axis.
    I want to change the color of the Y axis and/or labels with the corresponding color of the trend line.
    How can I do that?
  • Posted 7 May 2019, 4:28 am EST
    In order to change the color of labels, you could use the itemFormatter property of Axis class. Please refer to the sample below:
    https://jsfiddle.net/qvm31L4s/
  • Posted 7 May 2019, 4:14 pm EST
    How should I format the color from the html if I’m using a code for the Axis as the following?:
    <wj-flex-chart-axis [wjProperty]="'axisY'"
                                                        [position]="item.axisPosition"
                                                        [min]="item.axisMinimum"
                                                        [max]="item.axisMaximum"
                                                        [axisLine]="true"
                                                        [majorGrid]="this.chartSeriesItems.length === 1"
                                                        [minorGrid]="false"
                                                        [title]="item.axisTitle">
                                    </wj-flex-chart-axis>
  • Posted 8 May 2019, 4:27 am EST
    You may assign the fomatter function to the itemFormatter property of the wj-flex-chart-axis. Please refer to the following code snippet and the sample demonstrating the same:
    <wj-flex-chart [itemsSource]="data"
        [bindingX]="'country'">
        <wj-flex-chart-axis #axis
          [itemFormatter]="axisFormatter"
          [axisLine]="true"
          [title]="'title'">
         <wj-flex-chart-series [name]="'Sales'" [binding]="'sales'"></wj-flex-chart-series>
     </wj-flex-chart>
    // in ts file
    axisFormatter(engine, label){
        engine.textFill = 'darkred';
        label.cls = null;
        return label;
    https://stackblitz.com/edit/angular-vqezkx?file=app%2Fapp.component.ts
    ~Sharad
  • Posted 10 May 2019, 7:05 am EST
    Thank you sharad.tomer. It woks very well. But I still need extra help.
    How can I modify this code to use different colors for different Y axis. Y have up to 6 Y axis, and they appears when I add a new trend line.
  • Posted 13 May 2019, 9:03 am EST
    You could use the hostElement property of Axis class to get the host element of Y-Axis and you can apply the color accordingly. Please refer to the sample below:
    https://stackblitz.com/edit/angular-j9kae7
  • Posted 13 May 2019, 8:53 pm EST
    Thank you abhishek.dutta. Your mprovement with the color of the Y-axis line is excellent and I will use it.
    But my doubt is still pending.
    Suppose we have the example at https://stackblitz.com/edit/angular-j9kae7.
    But, instead of 1 Y-axis, I have 3 Y-axes: one for each variable “Sales, Expenses and Downloads”. And I want to use for the Y-axes the color of the variables in the chart, that is: Blue–>Sales, Orange–>Expenses and Green–>Download.
    How can I use different colors for different Y-axes? And, how could I use in the Y-axes the same colors of the variables in the chart?
  • Posted 14 May 2019, 3:19 am EST
    The other Y-Axis can also be coloured in the same way using hostElement property and then selecting the axis line. Please refer to the sample below demonstrating the same:
    https://stackblitz.com/edit/angular-t7tmv9?file=app/app.component.ts
  • Posted 17 May 2019, 4:00 pm EST
    Many Thanks!!!
