Mvc FlexGrid DataMap binding
Posted by: reidar.lange on 31 March 2023, 9:37 am EST
  • Posted 31 March 2023, 9:37 am EST - Updated 31 March 2023, 9:39 am EST
    Fearly new to this. I am trying to create a combobox column specifying both key and displayvalue.
    For now I only use an empty List<KeyValuePair<string,string>> named test as datasource for the column.
    It will not compile and gives the following error
    **Severity Code Description Project File Line Suppression State
    Error CS1503 Argument 1: cannot convert from ‘System.Collections.Generic.List<System.Collections.Generic.KeyValuePair<string, string>>’ to ‘System.Action<C1.Web.Mvc.Fluent.CollectionViewServiceBuilder>’ SWPP C:\Users\reidar.BAS\source\repos\ShipWeightPlussMVC\SWPP\Views\ItemFl\Index.cshtml 59 Active
    It fails here:
    .DataMap(dm => dm.DisplayMemberPath(“Key”).SelectedValuePath(“Value”).Bind(test))
    string statuses = ViewBag.Statuses;
    List<KeyValuePair<string, string>> test = new List<KeyValuePair<string, string>>();
    @(Html.C1().FlexGrid<SWPP.Models.ITEM_ViewItem>()
                            .Bind(
                                bl => bl.InitialItemsCount(100)
                                        .Bind(Url.Action("GridReadData"))
                                        .Update(Url.Action("GridUpdateItem"))
                                        .Delete(Url.Action("GridDeleteItem"))
                                        .Create(Url.Action("GridCreateItem"))
                            .Id("theGrid")
                            .AutoGenerateColumns(false)
                            .IsReadOnly(false)
                            .Height("800px")
                            .Filterable(f => f.DefaultFilterType(FilterType.Both))
                            .AutoSearch(true)
                            .CaseSensitiveSearch(true)
                            .CssClass("grid")
                            .AutoRowHeights(false)
                            .AllowDelete(true)
                            .AllowAddNew(true)
                            .NewRowAtTop(false)
                            .SelectionMode(SelectionMode.MultiRange)
                            .Columns(b =>
                                b.Add(cb => cb.Binding("ProjectID").Visible(false));
                                b.Add(cb => cb.Binding("UniqueNo").Visible(false));
                                foreach (var h in Model.Headers)
                                    if (h.InputSpec.Type == ShipWeightPlussMVC.Models.InputSpec.InputTypes.Edit)
                                        b.Add(cb => cb
                                        .Binding(h.FieldName)
                                        .Header(h.Caption)
                                        .DataType(h.DataType)
                                        .IsReadOnly(h.ReadOnly)
                                    else
                                        b.Add(cb => cb
                                        .DataMapEditor(DataMapEditor.DropDownList)
                                        .DataMap(dm => dm.DisplayMemberPath("Key").SelectedValuePath("Value").Bind(test))
                                        .Header(h.Caption)
                                        .Editor($"{h.FieldName}Editor")
  • Posted 3 April 2023, 2:31 pm EST
    For this, you should pass the proper list of objects of a class that has valid properties with DataType and it should be binding the properties can be set as DisplayMemberPath and SelectedValuePath.
    Manish Gupta
