Need to find the object type whether it is Row or Column (wijmo.grid.GridPanel)
Posted by: mmurugesan on 5 April 2019, 5:21 pm EST
    Posted 5 April 2019, 5:21 pm EST
    I need to find the object type whether it is Row or Column. Here is my sample code (in TypeScript).
    public myMethod(panel: wijmo.grid.GridPanel, r: number, c: number, cell: HTMLElement): void {
    let className: any;
    if (panel.columns[c].binding === “Value”) {
    className = this.getClassName(panel.rows[r]);
    } else {
    className = this.getClassName(panel.columns[c]);
    // code continues here
    Here is the code in getClassName function:
    private getClassName(value: any): boolean {
        let columnName: any;
        let fieldDetails: FieldDetails;
        [b]if (value.GetType() === wijmo.grid.Row) {[/b]
            columnName = this.flexGrid.columns[1].header;
            fieldDetails = value._data.row.FieldDetails;
        [b]}else if (value.GetType() === wijmo.grid.Column) {[/b]
            columnName = value._hdr;
            fieldDetails = this.fields.find(field => field._aliasName === columnName);
    In my above getClassName, the value.GetType() in if and else if throws error as undefined.
    How to find the value type whether the passed object is Row / Column type ?
    Appreciate your ideas/suggestions.
  • Posted 8 April 2019, 6:19 am EST
    HI,
    Inorder To check whether the object passed is an instance of a row or column, I suggest you should use instanceof operator instead of getType:
    if (value instanceof wijmo.grid.Row) {
    }else if (value instanceof wijmo.grid.Column) {
  • Posted 8 April 2019, 10:17 am EST
    Excellent. This works. Thank you very much…
