Nested table expand/collapse on row click
Posted by: jmisquez on 31 May 2022, 4:58 am EST
    Posted 31 May 2022, 4:58 am EST - Updated 3 October 2022, 11:56 am EST
    Im trying to expand/collapse wjFlexGridDetail on row click but i cannot find a way to make it work, also i dont want the row header i want to make looks like normal color, something like this:
    the issue is that the ExpandSingle doesnt work because im handling the expand/collapse with a gridClickHandler event:
    html
     <wj-flex-grid
        #flex
        [itemsSource]="flexData"
        [isReadOnly]="isReadOnly"
        [alternatingRowStep]="alternatingRowStep"
        [showMarquee]="showMarquee"
        (initialized)="flexInitialized(flex)"
        (selectionChanged)="onSelectionChanged()"
        (click)="gridClickHandler($event,grid)"
        [itemFormatter]="itemFormatter">
    .ts
      public gridClickHandler(e: any, grid: any) {
        if (!this.flexGridDetail) return;
        const ht = grid.hitTest(e);
        const isButton = ['wj-cell-maker', 'fa'].some( (className: string) => ht.target.classList.contains(className));
        if (!isButton) {
          if (this.flexGridDetail.isDetailVisible(ht.row) && this.flexGridDetail.isDetailAvailable(ht.row)) {
            this.expandedRow = null;
            this.flexGridDetail.hideDetail(ht.row);
          } else {
            this.expandedRow = ht.row;
            this.flexGridDetail.showDetail(ht.row);
    the issue with the code above is that the row.index increase when the rowDetail is displayed, so the row doesnt match as expected.
    so i want to make it that only one row can be visible at a time and make handle the toggle on row click, also i want to color the entire row when i hover or select, so if i add the rowHeader it doesnt color, i dont want this:
  • Posted 1 June 2022, 9:52 am EST
    Please refer to the sample link below demonstrating, how to add a custom expand/collapse icon on a column using templates:
    https://stackblitz.com/edit/angular-dc9ept?file=src%2Fapp%2Fapp.component.html
    Let us know if this works for you.
  • Posted 2 June 2022, 2:10 am EST - Updated 3 October 2022, 11:56 am EST
    I want to expand/collapse the nested grid when i click on the row, also i want to show a custom icon and i want that the entire row change color on hover and selection.
    so im facing 3 issues:
    1.- the RowHeaders doesn’t change color on Selection / Hover, example:
    Is there a way to change the Color of the RowHeader?
    2.- I want to expand or collapse the Row on Selection change, so the expected behaviour is to click in any place in the Row and expand or collapse the Details i already try with the gridClickHandler but when i try to use that i cannot use the “ExpandSingle” and i can open more than one RowDetails at the same time.
    3.- I want to focus to the current Row that is showing the details, scroll down or up to make the Selected Row to looks like the it was a Header / First Item of the grid.
    btw, the custom icon help me to change the +/- icon and use caret, thanks for that one
  • Posted 7 June 2022, 12:16 am EST
    We apologize for the delayed response, you may refer to the sample link below demonstrating the above points:
    https://stackblitz.com/edit/angular-vmmbqc?file=src%2Fapp%2Fapp.component.ts
    Please let us know if you have any doubts.
