Posted 1 March 2021, 5:54 am EST - Updated 3 October 2022, 2:06 pm EST
hi,
like I wrote in the header the order of the month is wrong when you use the format MMM YYYY (short month & long year) with the German culture file.
The only month which doesn’t work correctly and appears at the wrong place is Mrz, which is short for März (=March).
At first I guessed the problem came from the fact that the month has an ‘ä’ in its longer form, but there is no problem with the order when you set the format to MMMM YYYY and therefore see the whole name.
You can see the error when in your examples, e.g. https://www.grapecity.com/wijmo/demos/OLAP/PivotGrid/Overview/purejs
when you set the culture to German
(insert in the html )
change the date-format to MMM yyyy (Line 23 in the app.js: dateField.format = ‘MMM yyyy’
and put the date in the columns
In the resulting table Mrz 2018-Mrz 2020 is between Jan 2021 and Sep 2018
Thank you and best regards
