Posted 20 August 2020, 1:00 pm EST
Hey Team,
Is there a way to override the default filtering and sorting of wijmo flex grid in angular2. I want to update the data myself on filter and sort change.
Posted by: karanpreet.singh on 20 August 2020, 1:00 pm EST
Hey Team,
Posted 21 August 2020, 2:55 am EST
Hi Karanpreet,
There is no direct way to override filtering and sorting. To override the filtering in the grid, you will have to override the apply method of FlexGridFilter:
const _oldApply = gridFilter.apply;
// use the function keyword and not the arrow functions
// to save the this scope
gridFilter.apply = function() {
// your custom implementation
// call the original method like this
// _oldApply.call(this);
This will override the apply for each of the column. You can also override each column separately:
var colFilter = gridFilter.getColumnFilter('country');
const _oldApply = colFilter.apply;
colFilter.apply = function(value) {
// implementation
// _oldApply.call(this, value):
In sorting, there is no direct apply method. But, there is a sortComparer property which can be used to provide custom implementation on how to sort 2 values. This property is a part of CollectionView since sorting is applied on collection view and not the grid.
Example: https://www.grapecity.com/wijmo/api/classes/wijmo.collectionview.html#sortcomparer
I hope this helps.
