Posted 30 March 2021, 6:22 am EST
Hi Team,
In a pivot grid , I was trying to find the solution to add column in Value section automatically, instead of row section, when user check the choose field report section to add filed in grid.
Posted by: razatalha750 on 30 March 2021, 6:22 am EST
Hi Team,
Posted 31 March 2021, 1:30 am EST
Hi razatalha750,
This is an expected behavior. When the fields that are of value type and are checked, then they are automatically moved to the value fields section. And if the field is of dimension type, then it is moved to the row fields section. Unfortunately, we cannot change this behavior because it is internal logic.
