Posted 12 December 2023, 5:56 am EST
To achieve the desired functionality please add a custom field in fields array. The getAggregateValue of this field will then be used to calculate the value based on the other two columns present in the PivotGrid.
Please refer to this code snippet for reference:
fields: [
{ binding: 'product', header: 'Product' },
{ binding: 'date', header: 'Date', format: 'yyyy "Q"q' },
{ binding: 'sales', header: 'Sales', format: 'n0' },
{ binding: 'expenses', header: 'Expenses', format: 'n0' },
header: 'Balance',
dataType: 'Number',
aggregate: 'Sum',
format: 'c0',
getAggregateValue: (item) => {
return item.Sales - item.Expenses;
Please refer to this API link for more information on getAggregateValue property:
https://developer.mescius.com/wijmo/api/classes/wijmo_olap.pivotfield.html#getaggregatevalue
You may also use the getValue property of the PivotField to do some calculations based on the raw data item. Please refer to this API link for more information on getValue property: https://developer.mescius.com/wijmo/api/classes/wijmo_olap.pivotfield.html#getvalue
I have prepared a sample in Vue demonstrating the same: https://stackblitz.com/edit/vue-example-1-sr8jpz
