Please support Angular CLI Strict Mode
Posted by: stephen on 4 January 2021, 2:54 pm EST
    Posted 4 January 2021, 2:54 pm EST
    New Wijmo user here :slight_smile:
    Please consider supporting Angular CLI Strict Mode for all the good reasons it is intended:
    https://blog.angular.io/angular-cli-strict-mode-c94ba5965f63
    Right now, when building in strict mode, I see errors such as ```
    Property ‘pageChanged’ in type ‘CollectionView’ is not assignable to the same property in base type ‘IPagedCollectionView’.
    I am attaching two simple Angular 11 projects that use the Grid component. The projects are identical except for one using strict mode (build fails) and the other without strict mode (works fine).
    I imagine it will be a non-trivial task to make Wijmo work with strict mode, and appreciate your development efforts all the more.
    Thanks.[zip filename="ng-app-nonstrict.zip"]https://gccontent.blob.core.windows.net/forum-uploads/file-d522e7fc-87de-415f-a97d-6613f7ed3864.zip[/zip][zip filename="ng-app-strict.zip"]https://gccontent.blob.core.windows.net/forum-uploads/file-80f83b52-04ab-466a-8efb-f6d3dbbb98a5.zip[/zip]
  • Posted 5 January 2021, 4:59 am EST
    Thank you for evaluating wijmo.
    I’ve escalated this issue to the dev team for further investigation and will let you know about updates regarding the same. The internal tracking Id for the issue is #470307.
    Sharad
  • Posted 9 June 2021, 6:44 pm EST
    Thank you for adding support for Angular strict mode in Wijmo 2021 v1 (Build 5.20211.794) - June 3, 2021.
    Much appreciated!
