Problems with Wijmo dev kit Angular samples
Posted by: stephen on 4 January 2021, 3:07 pm EST
    Posted 4 January 2021, 3:07 pm EST
    I am blown away by the breadth and depth of the Wijmo samples you provide! But unfortuntately I am also a bit disapointed by problems in the same samples (as they pertain to Angular) in the Wijmo dev kit.
    In version 5.20203.748 of the dev kit, I am experiencing the following issues with the Angular samples:
    • “As far as I can see, each and every instance of package.json reference “@grapecity/wijmo.angular2.all”: “master.min”. That package version is invalid according to npm. Once replaced with a valid version, then I can install the packages and build the projects”
    • “The feature and reference samples use Angular 7 and 8. Those are dated version in the fast-changing Angular world. It will be real nice to see these composed using the latest Angular (currently 11). That implies removing/replacing some packages that are no longer relevant.”
    Thank you and keep up the good work!
  • Posted 5 January 2021, 4:39 am EST
    Thank you for your valuable feedback.
    • Thank you for reporting, I’ve escalated this issue to the concerned team for a fix. The internal tracking id for the same is #470306. I’ll update you on this thread after the issue is fixed.
    • The samples are updated whenever there is any major change in the syntax. However, you may rest assured that wi mo supports the latest angular version and if you face any issues then let us know and we would be glad to assist you. Also, if you need the samples to be in the latest angular version then please let us know and we would create an enhancement request on your behalf for the same.
    Sharad
  • Posted 9 June 2021, 6:36 pm EST
    Thank you, I notice that you recently updated the examples to Angular 11. Awesome!
