Range delete doesnt work well with Immutability Provider
Posted by: tdnooij on 30 June 2025, 10:21 am EST
    Posted 30 June 2025, 10:21 am EST
    It’s currently not possible to delete cells from a single column. Interestingly, when multiple columns are selected, deletion works as expected. I would expect the same behavior even when only one column is selected.
    For example, try deleting 3 elements from the “Country” column alone, and then compare that with deleting 3 elements when both “Country” and “Product” columns are selected.
    You can observe this in the following demo:
    https://developer.mescius.com/wijmo/demos/Grid/Data-binding/ImmutableData/Redux/EditableReduxGrid/react
    The expected behavior would be similar to what’s shown in the example without the ImmutabilityProvider.
    https://developer.mescius.com/wijmo/demos/Grid/Columns/ColumnPicker/react
  • Posted 1 July 2025, 6:17 am EST
    Hi Thomas,
    This query is answered on our other portal, here’s a copy of the response -
    This seems like an unexpected behavior for the ImmutabilityProvider, so we have forwarded this issue to the engineering team for further investigation with internal tracking ID - WJM-36636. We will update you when we have an update from the engineering team on the same.
    For now, as a workaround, you can wrap the content of the ‘dataChanged’ event handler function inside a ‘setTimeout’ function. Please refer to the following sample demonstrating the same - https://jscodemine.mescius.io/share/AsyIu3I3OkKTp6VgZSaYXw/
  • Posted 11 November 2025, 5:19 am EST
    Hi Thomas,
    This issue is now fixed in the latest Wijmo version, i.e., 5.20252.42. You can verify it in the following demo sample - https://developer.mescius.com/wijmo/demos/Grid/Data-binding/ImmutableData/Redux/EditableReduxGrid/react
    Vivek Pannu
