Regarding license Purchase
Posted by: technical.store.technical on 11 June 2021, 1:00 am EST
  • Posted 11 June 2021, 1:00 am EST
    We have some doubts in license part,
    If we buy a license, then
    1. As we use a install command to install the free trial version of Wijmo grid.
      Are we suppose to use the same command to install it after Purchasing license? Then what will be the difference?
    2. In this trial version we never added any extra folder or file explicitly in our application, as the command was enough for us in order to install all the features.
      So do we need to add any extra File/folder explicitly in our application after buying license?
  • Posted 14 June 2021, 12:00 am EST
    Can you please help us with an answer.
  • Posted 14 June 2021, 9:56 am EST
    Thanks for taking interest in Wijmo. You do need to install anything extra or add any files or folders. The same process will be followed even after you have purchased your license. The only thing you will need to do after the purchase is to create a distribution key and use the wijmo.setLicenseKey method to license the application.
    The following link describes how you can register your serial to create a distribution key and how you can use this distribution key to license your application:
    https://www.grapecity.com/wijmo/licensing
    Let me know if this helps.
